Hikvision IPC-D121H-M Error 2022
crdenim11
Nov 10, 2019
1
Scotland
I just recently bought this camera on Amazon and it didn't come with the default username, password and IP address. I managed to get the IP address via a bit of luck and a Network scan, but I am still unable to reset the password of the camera. I have sent Hikvision the XML file and they sent back the recovery file, to which it come back with "Unable to Reset password. Other 2022".
I would really appreciate the help.
Reboot ypur ipc 1 time, generate XML, send to hikvision & be sure that your ipc not rebooted.
You can check it at SADP(start time)
So, try again
I also have the same model as yours and got the same problem. did u manage to reset the password. i tried many codes but all failed.
any advice.
