- Sep 11, 2015
- 2
- 0
I just purchased an authentic Hikvision NVR
1.) Hikvision DS-7716NI-SP/16 Channel POE NVR with V3.1.3 Firmware, build 08/28/14
2.) Hikvision DS-2CD2132F-IS 2.8mm IP Camera with V5.2.8
Firmware, build 03/01/15
3.) Hikvision DS-2CD2132F-IS 4.0mm IP Camera with V5.3.0
Firmware, build 07/01/15
So initially I started out with the NVR and the 2.8mm camera just a month ago and I intended on adding more cameras as I went along.
When I first set up just the one 2.8mm camera everything connected with no Hikcups. The " Plug and Play " interface connected the camera as promised.
Now I attempted to connect the second 4.0mm camera and no dice. The NVR is suppose to assign and IP address to the camera. I attempted to manual method by editing the cameras IP address assigned to that port by inputting the address that is printed on the camera box, no such luck. I've tried rebooting the camera but that only prompted of warning that the restored failed, please try again.
I've rebooted the NVR and to no avail.
Now the 2.8mm camera will not connect either. The reason I purchased the system is for the lack thereof a computer or interweb.
I greatly appreciate any help you may be.
