Hi guys.
I am about to start the house build process soon and am looking at hikvision ip intercom front door bell to work out electrical cable provisions.
Is it possible to connect any of the poe door intercoms to be displayed on the TV and if so is it reliable or u stable and am I better of getting a euify2k ip doorbell and connect to alexa/firesticktv.
Basically, I am trying to work out if I need additional network ports to support an indoor monitor or if it's a more reliable solution to use another doorbell system that can automatically display on the TV when someone pressed the doorbell.
Is there much difference in responsiveness between a wifi configured indoor hikvision monitor and a peo one? Nothing the front doorbell cam will be ip/poe based.
Appreciate your thoughts on this.
Thanks
Sent from my SM-G998B using Tapatalk
Thanks
