Live in apartment block with 6 flats and there is a Hikvisoin access station outside with a DS-KH6320-WTE1 indoor video screen in the flat. Considering replacing with a DS-KH9510 unit. Couple of questions that would be great to get any help with:
1) Can I simply replace the 6320 with the 9510 unit - 6320 is PoE so is it simply plug in RJ45, set 9510 to auto DHCP and will it just work, or will there be config work needed on the IVMS console (which I dont currently have access to)
2) Any experiences with running 3P android apps on the 9521 - wanted to install the Honeywell Home and Lutron apps to control heating and lighting
3) I have a wired Texecom alarm with a wired door sensor and wired PIR - can I hardwire these into the Alarm terminals on the 9510 or would I need to add something like the AX Pro wireless setup to integrate into the 9510 and hikconnect
Finally read somewhere that the 9510 Android units maybe being replaced with newer models soon - any insights from the forum,
Thanks for any help,
