Hi everyone
I have a simple 4 camera setup where my cameras are wired directly into the Hikvision NVR
What I have is:-
NVR - Hikvision DS7604 (4 port POE recorder)
Cam 1 - DS-2CD2532F low profile dome
Cam 2 - DS-2CD2532F low profile dome
Cam 3 - DS-2CD2532F low profile dome
Cam 4 - DS-2CD2332-1 large dome
I have purchased on line a replacement camera DS-2CD3345 4MP H.265 to replace camera 4 for better resolution purposes.
When I plug the camera into Cam 4 Ethernet cable my NVR will NOT show the camera no matter what I do.
I read that I should use SADP to verify the new camera but the software only picks up my NVR on my home network as my cameras are wired directly into the NVR.
When I installed the system last year it was plug and play.
Can anyone advise on how I can activate the new camera.
Your help is greatly appreciated.
Cheers vacman
What I have is:-
Cheers vacman
