Hi,
I have a hikvision DS-2CD2146G2-ISU camera which has developed a fault. It partially works in that when turned on I am able to access the camera via http web browser but its laggy and crashes a lot. SADP tool recognises the camera. I thought it may be a firmware issue so i tried to update the firmware via the web browser but it failed (did not even send file). I then tried via tftp server but nothing happened, it acknowledges the camera, but no file is sent. I then connected to the camera via serial cable and could see an error repeating in the log which was as below
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 10 min and 17 sec )
I was able to perform firmware update on the camera via serial cable & tftp but the above error has still persisted. Any ideas on how to fix this?
Full boot up code is attached below. I can see a few errors such as
1 - Run tee-supplicant ... device open: No such file or directory
2- ./loadNT9852x.sh: line 220: mdev: not found
3 - Jan 1 12:52:17 bsp.err kernel: [ 12.438545] Error: Driver 'nvt_pwm' is already registered, aborting...
4 -
debug_demo_mdk_create!
mount: mounting none on /proc/bus/usb failed: No such device
mount: mounting debugfs on /proc/bus/ failed: Device or resource busy
chmod: /bin/dsp_test: No such file or directory
4 -
Code:
dma1 zq_trim[e], ldo_trim[c]
DDR3_2133ver 2.00
ini_ver: 0x60210205
CPU1000 DONE
>dma1 ssc 1
dma ok
2 DR
dma2 zq_trim[e], ldo_trim[c]
dma1 ssc 1
dma2 ok
UNZOK!
Loader Start ...
LD_VER 03.01.07
528_DRAM1_1066_4096Mb_DRAM2_1066_4096Mb 04/10/2021 10:48:59
NAND,BS= 0x00000002
gpio ID2 0x00000000
gpio ID3 0x00000000
SPI NAND MID=000000EF DEV=000000AA
ld.LdCtrl2 0x00000000
LdCtrl2 0x00000000
teeos_addr 0x02000000
uboot_addr 0x0E000000
uboot_size 0x02000000
smp(tee2)
core2_jump_program 0xF07C0500
code2JumpCodelen 0x00000010
core2_entry2_addr 0x01FC0000
core2_entry_checksum 0x0000C40F
core2_entry_program 0xF07C0510
code2EntryCodelen 0x000001BC
0xF07F8000= 0x02000180
core2_reset
2ajcor1awaitump 0x02000180
abceRS2WK2
U-Boot 2019.04-svn1177869 (Apr 10 2021 - 10:49:09 +0800), Build: jenkins-Frontend.BSP.CCI.devCloud-3254
CPU: 999 MHz
DRAM: 256 MiB
l2cache:0
l2cache:1
bootmode = 0 addr=00007e00!
NAND: id = 0xef 0xaa 0x21 0x00
nvt spinand 4-bit mode @ 12000000 Hz
128 MiB
MMC: 0
misc_init_r: boot time: 1361907(us)
misc_init_r: boot time: 1365909(us)
Net: INTER MII
[Uboot] In release mode!
Hit Ctrl+u to stop autoboot: 0
|NUL ethaddr| error: auto upgrade.(error!!)
TFTP server auto connect disabled
Unknown command 'crc' - try 'help'
booting from sys part...
Load kernel to 0xc700000 ...
<sbal_wb_aes_update>...decrypt
<sbal_seboot>body_total_len=7724352
<sbal_seboot>verify success ##successful to load enc_uImage##
gzip_image_size 75dd28 image_size f51d7c
nvt_ker_img_ungzip_linux: gz_uncompress linux
nvt_ker_img_ungzip_linux: generating uImage header for linux
CHIP_1.
Succeed!
## Booting kernel from Legacy Image at 0c720000 ...
Image Name:
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 16063868 Bytes = 15.3 MiB
Load Address: 00008000
Entry Point: 00008000
## Flattened Device Tree blob at 0c700000
Booting using the fdt blob at 0xc700000
Loading Kernel Image
Loading Device Tree to 087dd000, end 087fffff ... OK
Starting kernel ...
l2cache:0
Disable MMU
Clear MMU
Uboot L2 cache aux val: 0x72420000
Uboot L2 cache prefetch ctrl val: 0x70000000
Uboot L2 cache ctrl val: 0x00000000
Done
SW2
starting pid 159, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
create static device nodes under /dev dir
>>>run pre_app_hook
done
waiting for /dev/ubi1_0.
waiting for /dev/ubi3_0.
>>>run post_app_hook
process/
process/davinci_bak
Jan 1 12:52:11 bsp.warn kernel: [ 6.778172] phydev exist: resume phy
Jan 1 12:52:11 bsp.warn kernel: [ 6.778212] nvt_resume: find node^M
Jan 1 12:52:11 bsp.warn kernel: [ 6.778218] nvt_resume: led-inv found^M
Jan 1 12:52:11 bsp.warn kernel: [ 6.778223] nvt_resume: led-inv = 1^M
Jan 1 12:52:11 bsp.warn kernel: [ 6.778239] nvt_resume: pinmux 0x12^M
Jan 1 12:52:11 bsp.warn kernel: [ 6.801730] DWC_ETH_QOS_yinit: apb_clk 120000000 Hz^M
Jan 1 12:52:11 bsp.alert kernel: [ 6.802751] Queue0 Tx fifo size 4096, Rx fifo size 4096
Jan 1 12:52:11 bsp.alert kernel: [ 6.802768] Disabled JUMBO pkt
Jan 1 12:52:11 bsp.alert kernel: [ 6.802786] Enabled Rx watchdog timer
Jan 1 12:52:11 bsp.alert kernel: [ 6.802795] Enabled TSO
Jan 1 12:52:11 bsp.alert kernel: [ 6.802799] Disabled Rx Split header mode
Jan 1 12:52:11 bsp.warn kernel: [ 6.802825] phydev exist: start phy
Jan 1 12:52:11 bsp.info kernel: [ 6.813166] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
process/database_process
process/daemon_fsp_app
process/net_process.lzma
process/hostapd.lzma
applib/
applib/libsqlite3.so.lzma
applib/libfsp_base.so.lzma
applib/libwebsockets_server.so.lzma
applib/libiconv_utf8Gbk.so.lzma
applib/libcrypto.so.lzma
applib/libssl.so.lzma
applib/libipc_unix.so
applib/libosip2.so
applib/libosipparser2.so
applib/libhikosip.so
applib/libserial_cmpt.so
applib/libcjson.so
applib/libprocess.so
applib/libremote_dbg.so
applib/libsave_alarminfo.so
applib/libcamflash_ipc.so
applib/libsyslog.so
applib/libhiksyslog.so
applib/libispfrontc.so
applib/libzoomcam_ipc.so
applib/libdadsp.so
hikmdk
hikdsp
Jan 1 12:52:14 bsp.warn kernel: [ 8.897564] DWC_ETH_QOS_adjust_link: start tx/rx^M
Jan 1 12:52:14 bsp.info kernel: [ 8.897584] DWC_ETH_QOS f02b0000.eth eth0: Link is Up - 100Mbps/Full - flow control rx/tx
Jan 1 12:52:14 bsp.info kernel: [ 8.897625] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
g5_isp_config.tgz
libg5_isp_ipc.so
ptzCfg.bin
ASC32
ASC16
GBK
serialCom
cellular_service
diald
chat
pppoed
pppoe
pppd
t1
da_info
execSystemCmd
sound.tar.gz
hikdrv/8189fs.ko
hikdrv/8192fs.ko
hikdrv/alarm.ko
hikdrv/an41908.ko
hikdrv/base.ko
hikdrv/bcm4359/
hikdrv/bcm4359/nvram_ap6398s.txt
hikdrv/bcm4359/nvram.txt
hikdrv/bcm4359/fw_bcm4359c0_ag_apsta.bin
hikdrv/bcm4359/fw_bcm4359c0_ag.bin
hikdrv/bcmdhd_sdio_bcm4359.ko
Jan 1 12:52:15 bsp.notice kernel: [ 9.898026] random: crng init done
hikdrv/cdc_ether.ko
hikdrv/cdc_ncm.ko
hikdrv/cfg80211.ko
hikdrv/detect_sensor.ko
hikdrv/digital_display.ko
hikdrv/dome_timer.ko
hikdrv/dram_split.ko
hikdrv/ehci-hcd.ko
hikdrv/epatch.ko
hikdrv/esensor.ko
hikdrv/fotg200-udc.ko
hikdrv/fotg210-udc.ko
hikdrv/g_ether.ko
hikdrv/g_ncm.ko
hikdrv/hikcore.ko
hikdrv/hikio.ko
hikdrv/klog.ko
hikdrv/libcomposite.ko
hikdrv/localvideo.ko
hikdrv/m25p80.ko
hikdrv/motor.ko
hikdrv/option.ko
hikdrv/pt_stm8.ko
hikdrv/switch.ko
hikdrv/u_ether.ko
hikdrv/uart232.ko
hikdrv/udc-core.ko
hikdrv/usb_f_ecm.ko
hikdrv/usb_f_ecm_subset.ko
hikdrv/usb_f_ncm.ko
hikdrv/usb_f_rndis.ko
hikdrv/usb_wwan.ko
hikdrv/usbnet.ko
hikdrv/usbserial.ko
hikdrv/vd_notify.ko
hikdrv/wifi_rf.tgz
hikdrv/wps.ko
nvtdrv/sample_nvt_ext.ko
./af/
./af/nvt_af.ko
./comm/
./comm/kdrv_comm.ko
./comm/nvtmem/
./comm/nvtmem/nvtmem.ko
./disp_if8b_lcd1_tp2803/
./disp_if8b_lcd1_tp2803/disp_if8b_lcd1_tp2803.ko
./display_panel/
./display_panel/nvt_dispdev_panel.ko
./iq/
./iq/nvt_iq.ko
./isp/
./isp/nvt_isp.ko
./kdrv_ai/
./kdrv_ai/kdrv_ai.ko
./kdrv_audioio/
./kdrv_audioio/audlib_hik_aec/
./kdrv_audioio/audlib_hik_aec/hik_audio_aec.ko
./kdrv_audioio/audlib_src/
./kdrv_audioio/audlib_src/nvt_audlib_src.ko
./kdrv_audioio/audlib_aec/
./kdrv_audioio/audlib_aec/nvt_audlib_aec.ko
./kdrv_audioio/audio_common/
./kdrv_audioio/audio_common/nvt_audio.ko
./kdrv_audioio/kdrv_audio/
./kdrv_audioio/kdrv_audio/nvt_kdrv_audio.ko
./kdrv_gfx2d/
./kdrv_gfx2d/kdrv_affine/
./kdrv_gfx2d/kdrv_affine/affine_neon/
./kdrv_gfx2d/kdrv_affine/affine_neon/kdrv_afn_neon.ko
./kdrv_gfx2d/kdrv_affine/kdrv_afn.ko
./kdrv_gfx2d/kdrv_gfx2d.ko
./kdrv_ive/
./kdrv_ive/kdrv_ive.ko
./kdrv_videocapture/
./kdrv_videocapture/kdrv_videocapture.ko
./kdrv_videocodec/
./kdrv_videocodec/kdrv_h26x.ko
./kdrv_videoout/
./kdrv_videoout/display_obj/
./kdrv_videoout/display_obj/kdrv_videoout.ko
./kdrv_videoout/ide/
./kdrv_videoout/ide/nvt_ide.ko
./kdrv_videoout/fbdev/
./kdrv_videoout/fbdev/nvt_fb.ko
./kdrv_videoprocess/
./kdrv_videoprocess/kdrv_vpe/
./kdrv_videoprocess/kdrv_vpe/kdrv_vpe.ko
./kdrv_videoprocess/kdrv_videoprocess.ko
./kflow_audiocapture/
./kflow_audiocapture/unit/
./kflow_audiocapture/unit/kflow_audiocap.ko
./kflow_audioout/
./kflow_audioout/unit/
./kflow_audioout/unit/kflow_audioout.ko
./kflow_common/
./kflow_common/kflow_common.ko
./kflow_gfx/
./kflow_gfx/nvt_gfx.ko
./kflow_gfx/videosprite/
./kflow_gfx/videosprite/nvt_videosprite.ko
./kflow_videocapture/
./kflow_videocapture/kflow_videocapture.ko
./kflow_videodec/
./kflow_videodec/unit/
./kflow_videodec/unit/kflow_videodec.ko
./kflow_videoenc/
./kflow_videoenc/unit/
./kflow_videoenc/unit/kflow_videoenc.ko
./kflow_videoout/
./kflow_videoout/unit/
./kflow_videoout/unit/kflow_videoout.ko
./kflow_videoprocess/
./kflow_videoprocess/kflow_videoprocess.ko
./loadNT9852x.sh
./net_flow_sample/
./net_flow_sample/netflowsample.ko
./nvt_vencrc/
./nvt_vencrc/nvt_vencrc.ko
./vpe/
./vpe/nvt_vpe.ko
insmod pre_insmod
Jan 1 12:52:17 bsp.info kernel: [ 12.425340] NVTMEM: 0.0.2
Jan 1 12:52:17 bsp.warn kernel: [ 12.451840] log.ko v1.4: Jul 23 2021 18:01:04 (mmap 0x91240000 size 0x21800)
Jan 1 12:52:17 bsp.warn kernel: [ 12.451861]
Jan 1 12:52:17 bsp.warn kernel: [ 12.451861] LOG base 0x968c1c00(ddr0) size 1K (start pointer 0x7f075354)
Jan 1 12:52:17 bsp.warn kernel: [ 12.451868] PAGE_OFFSET(0x80000000) VMALLOC START(0x97800000) HZ(100)
Jan 1 12:52:17 bsp.debug kernel: [ 12.452340] nvt_sif_init:
Jan 1 12:52:17 bsp.debug kernel: [ 12.452581] nvt_sif_probe:f0240000.sif
Jan 1 12:52:17 bsp.debug kernel: [ 12.452596] nvt_sif_probe:0. resource:0xf0240000 size:0x200
Jan 1 12:52:17 bsp.debug kernel: [ 12.452639] nvt_sif_probe:IRQ 0. ID51
Jan 1 12:52:17 bsp.debug kernel: [ 12.452814] nvt_sif_probe:DevID Major:253 minor:10
Jan 1 12:52:17 bsp.debug kernel: [ 12.453147] nvt_sif_drv_init:
Jan 1 12:52:17 bsp.warn kernel: [ 12.464661]
Jan 1 12:52:17 bsp.warn kernel: [ 12.491506] ERR:nvtmpp_parse_mmz_dt_p() dynamic_map not support 512MB/1GB^M
Jan 1 12:52:17 bsp.warn kernel: [ 12.492868] nvtmpp_init_mmz: ddr1 pa = 0x17200000 va = 0x98980000 , size = 0x8e00000
Jan 1 12:52:17 bsp.warn kernel: [ 12.501550] nvtmpp_init_mmz: ddr2 pa = 0x40000000 va = 0xa1800000 , size = 0x20000000
Jan 1 12:52:17 bsp.info kernel: [ 12.526742] affine_neon_module_initial: successfully
Jan 1 12:52:17 bsp.warn kernel: [ 12.535006]
Jan 1 12:52:17 bsp.warn kernel: [ 12.536320] AFFINE addr 0xfdca0000^M
Jan 1 12:52:17 bsp.warn kernel: [ 12.536425] nvt_affine_drv_init: done
Jan 1 12:52:17 bsp.warn kernel: [ 12.561688]
Jan 1 12:52:17 bsp.warn kernel: [ 12.563955] nvt_csi_probe:not fast boot
Jan 1 12:52:17 bsp.warn kernel: [ 12.601653] f0c20000.dce^M
Jan 1 12:52:17 bsp.warn kernel: [ 12.602831]
Jan 1 12:52:17 bsp.warn kernel: [ 12.603064] IRQ 0. ID37
Jan 1 12:52:17 bsp.warn kernel: [ 12.603256] DevID Major:253 minor:32
Jan 1 12:52:17 bsp.warn kernel: [ 12.700374] WRN:nvt_afalg_init() motor drv is null!^M
Jan 1 12:52:17 bsp.warn kernel: [ 12.700650] WRN:nvt_afalg_init() motor drv is null!^M
insmod post_insmod
./libDFR_Attribute_shared.so
./libDFR_Landmark_shared.so
./libhdal.so
./libprebuilt_ai.so
./libvendor_ai.so
./libvendor_ai_pub.so
./libvendor_media.so
dsp_G5.json
mv: can't rename '/home/dsp_extres/dsp_info': No such file or directory
cp: can't stat '/bin/dsp_info': No such file or directory
/bin
########## hikmdk build at 15:52:41--Sep 9 2021 ############
mdk_build_time:2021-09-09 15:52:41
mdk_svn_url:https://192.0.0.241/DSP/Frontend/Novatek/NT98525/G5/branches/baseline/IPC/PJ01TD20210803261_v5.7.1_ipc_base/mdk
mdk_svn_version:
Insmod ko start...
insmod: can't insert '/home/plat_module/hikdrv/base.ko': File exists
insmod: can't insert '/home/plat_module/hikdrv/hikcore.ko': File exists
insmod: can't insert '/home/plat_module/hikdrv/hikio.ko': File exists
Press Ctrl-C to stop ...
Jan 1 12:52:18 bsp.info kernel: [ 12.789444] nvt_audlib_aec driver for hik aec!
Jan 1 12:52:18 bsp.warn kernel: [ 12.869672] nvt_dispdev_module_init:
Jan 1 12:52:18 bsp.info kernel: [ 12.881001] Hello, panel: TP2803, is_ntsc 1
Jan 1 12:52:18 bsp.err hal_bsp[833]: [HAL_BSP][833][bsp_check_hikio_fd]:Please hal_hikio_init() first.
Jan 1 12:52:18 bsp.warn kernel: [ 13.568208] sample ext
Jan 1 12:52:18 bsp.info kernel: [ 13.576858] func:motor_module_init, successful to initialize motor!
Jan 1 12:52:18 bsp.warn kernel: [ 13.584966] [LOCALVIDEO][localvideo_init]:register miscdev @ "/dev/localvideo" success!
Jan 1 12:52:18 bsp.info kernel: [ 13.593295] nvt_gpio f0070000.gpio: HWIRQ: 40 IRQ: 296 ### Both Edge ###
Jan 1 12:52:18 bsp.info kernel: [ 13.599847] nvt_gpio f0070000.gpio: HWIRQ: 20 IRQ: 276 ### Both Edge ###
Jan 1 12:52:18 bsp.info kernel: [ 13.599943] nvt_gpio f0070000.gpio: HWIRQ: 21 IRQ: 277 ### Both Edge ###
Jan 1 12:52:18 bsp.info kernel: [ 13.600007] nvt_gpio f0070000.gpio: HWIRQ: 31 IRQ: 287 ### Both Edge ###
Jan 1 12:52:18 bsp.info kernel: [ 13.609429] [uart232]:default_setup: number = 0
Jan 1 12:52:18 bsp.info kernel: [ 13.609514] [uart232]:register uart2 port [2] success
Jan 1 12:52:18 bsp.info kernel: [ 13.610019] [uart232]:default_setup: number = 1
Jan 1 12:52:18 bsp.info kernel: [ 13.610109] [uart232]:register uart4 port [4] success
Jan 1 12:52:18 bsp.info kernel: [ 13.610562] [uart232]:default_setup: number = 2
Jan 1 12:52:18 bsp.info kernel: [ 13.610652] [uart232]:register uart3 port [5] success
Jan 1 12:52:18 bsp.info kernel: [ 13.610664] [uart232]:Successfully insmod uart232 module!
[PACK][DBG_ERRO][src/firm_unpack_lib.c][firm_pack_decode][260]:###### unpack source[0] bPackVerFlg=0x00,bPackDevFlg=1010010011111110021,iFirmMapFlg=0x00000001,iFirmKeyFlg=0x00000000
[PACK][DBG_ERRO][src/firm_unpack_lib.c][firm_pack_decode][262]:###### unpack source[0] iFirmOffset=0x0000006c,iFileLength=0x006716c5,iCheckSumU8=0x3355cd69
[PACK][DBG_ERRO][src/firm_unpack_lib.c][firm_pack_decode][290]:###pack[0] iFirmFlg=0x00650100,iPlatform=101,iDevMajor=111,iDevMinor=111,iLanguage=2
Jan 1 12:52:19 bsp.err hal_bsp[899]: [HAL_BSP][899][bsp_check_hikio_fd]:Please hal_hikio_init() first.
Jan 1 12:52:19 bsp.warn kernel: [ 14.646534] read headbuf = 224
Jan 1 12:52:19 bsp.warn kernel: [ 14.646724] <sbal_wb_aes_update>...decrypt
Jan 1 12:52:19 bsp.warn kernel: [ 14.648275] <sbal_wb_aes_update>...decrypt
Jan 1 12:52:19 bsp.warn kernel: [ 14.648931] <sbal_seboot>
Jan 1 12:52:19 bsp.warn kernel: [ 14.648938] body_total_len=243936
Jan 1 12:52:19 bsp.warn kernel: [ 14.733740] <sbal_seboot>
Jan 1 12:52:19 bsp.warn kernel: [ 14.733743] verify success
Jan 1 12:52:19 bsp.info kernel: [ 14.734512] ##successful to hik_decode_daemon_toplained :/home/daemon##
[PACK][DBG_ERRO][src/firm_unpack_lib.c][firm_pack_decode][400]:###file[0] szFileName=davinci.lzma,iFirmOffset=0x00000500,iFileLength=0x006711c5,iCheckSumU8=0xc18215b8
IEfile uncompressed.
Enter DB_main-------------------
DB_SHARE_MEMORY_ID 4442534d, sizeof(DEVICECONFIG) 3352232
shared memory address is: 0x76846000, sizeof(DEVICECONFIG) = 3352232
netprocess Infomation FSP_network_multi:
version: 1.9.0.765278 [21:14:27-Aug 6 2020]
Path: /Camera/Platform/Branches/branches_FSP_network_protocol/BASE/FSP_network_multi
Last Changed Rev: 931717
Last Changed Date: 2020-08-05 16:52:22 +0800 (Wed, 05 Aug 2020)
wait davinci set default...
[01-01 12:52:21][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:21][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:21][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:21][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
starting pid 911, tty '': '-/bin/psh'
BusyBox v2.0.1-1460430 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
# [01-01 12:52:22][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:22][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:22][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:22][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[DAEMON][DBG_INFO][src/daemon.c][firm_file_output][390]:firm unpack file : /home/process/davinci.lzma succ.
[DAEMON][DBG_INFO][src/daemon.c][app_system_exec][265]:system cmd [lzma -df /home/process/davinci.lzma]
[01-01 12:52:23][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:23][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:23][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:23][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 12:52:24][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:24][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:24][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:24][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-01 12:52:25][pid:0][OTHER][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-01 12:52:25][pid:904][OTHER][ERROR]from daemon ack, dst not work len 0, load_type is [0x10012]
[01-01 12:52:25][pid:904][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-01 12:52:25][pid:904][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[DAEMON][DBG_INFO][src/daemon.c][app_system_exec][282]:system [lzma -df /home/process/davinci.lzma] succ.)
[DAEMON][DBG_INFO][src/daemon.c][app_system_exec][265]:system cmd [/home/process/davinci &]
[DAEMON][DBG_INFO][src/daemon.c][app_system_exec][282]:system [/home/process/davinci &] succ.)
[PACK][DBG_HINT][src/firm_unpack_lib.c][firm_pack_decode][339]:###pack num=1,decode succ=1,permit denied=0
[01-01 12:52:26][pid:0][OTHER][INFO]boot_debug--21.401: ==main=
[01-01 12:52:26][pid:0][OTHER][INFO]boot_debug--21.403: user_sysinit in
[01-01 12:52:26][pid:0][SYSINIT][ERROR]
▒▒▒ܰ汾
▒豸▒ͺ▒: 0x24043 ,▒▒▒▒▒ͺ▒:DS-2CD2186G2-ISU
[01-01 12:52:26][pid:0][SYSINIT][ERROR]bootParms.icrSupport = 130
[01-01 12:52:26][pid:0][SYSINI^Qdavinci receive cmd_query_davinci_param.
[01-01 12:53:17][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
S: cmd_query_davinci_param
config_davinci_param
[01-01 12:53:17][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:17][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:17][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:18][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:18][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:18][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:18][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:19][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:19][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:19][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:19][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:20][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:20][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:20][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:20][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:21][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:21][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:21][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:21][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 0 min and 50 sec )
[DSP][ERR]<1000946>[DSP]<main><5432>:DSP_SMART_INIT fail !! smart_bootInfo = 0 !!!
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 10
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[audioVolume]
[01-01 12:53:22][pid:0][DSP][ERROR]send fail ret= -9
[01-01 12:53:22][pid:0][DSP][ERROR]mdk_av_get_audio_volume error!
[01-01 12:53:22][pid:0][UNI_IF][ERROR]ioctl(iopFd, HIKIO_SET_AUDIO_INPUT_MODE) error!
Jan 1 12:53:22 bsp.err kernel: [ 77.725956] nvt_i2c f03a0000.i2c3: i2c_nvtim_xfer_msg(675) NACK!
Jan 1 12:53:22 bsp.warn kernel: [ 77.725976] [LOCALVIDEO][tp2803fe_check_exist]:i2c_reg_read_byte TP2803_REG_ID_H(0xFE) error!
Jan 1 12:53:22 bsp.warn kernel: [ 77.725982] [LOCALVIDEO][cvbs_chip_check]:cvbs chip TP2803_FE is not exist!
Jan 1 12:53:22 bsp.warn kernel: [ 77.725987] [LOCALVIDEO][cvbs_chip_match_for_i2c]:cvbs_chip_check failed! ret = -1
[01-01 12:53:23][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:23][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_davinci_init_finish = FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:23][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:23][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:23][pid:0][HW_IF][ERROR]get_hal_mcu_info_task start.
[01-01 12:53:23][pid:0][UNI_IF][ERROR]not support light!!!
[PSWD][0095]:public_base64_len 188 len 140
[PSWD][0490]:public_base64_len 188 len 140
[PSWD][0524]:init_default_param_lib rsa_version[6]
[QR_CTRL]malloc_setting_size_buffer =0x0x1b1b308
[QR_CTRL]malloc_setting_size_buffer =0x0x1b12838
[QR_CTRL]malloc_setting_size_buffer =0x0x1b24c80
[QR_CTRL]malloc_setting_size_buffer =0x0x1b0d530
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_isp_config.json in dir[/dav/qr_isp_config.json]!
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_jx_config.json in dir[/dav/qr_jx_config.json]!
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_app_config.json in dir[/dav/qr_app_config.json] !
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_isp_source.json in dir[/dav/qr_isp_source.json] !
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_jx_source.json in dir[/dav/qr_jx_source.json] !
[01-01 12:53:23][pid:0][SENSOR][ERROR][qr_malloc_json_buffer][QR_CTRL]not find qr_app_source.json in dir[/dav/qr_app_source.json] !
[01-01 12:53:23][pid:0][SENSOR][INFO][qr_malloc_json_buffer][QR_CTRL]malloc_setting_size_buffer SUCCESS !
[assemble_qr_config_json]--qr_config_json is {
[assemble_qr_config_json]--qr_transmit_json is {
"data": []
[assemble_qr_transmit_json]-final-qr_transmit_json is {
"data": []
front_task_dep_func_callback_init OK!
front_task_enable_init OK!
-------------------------------------------------send_heart_beat_timer------------------------------------------
[01-01 12:53:23][pid:0][SENSOR][INFO]RULE ENGINE: the icr task initialize successfully!
hwif_malloc_intel_buffer buffer_num=2
hwif_malloc_intel_buffer buffer[0]=0x0x70af7008
hwif_malloc_intel_buffer buffer[1]=0x0x704fe008
p_img_slot->data[0]=0x0x70af7008
p_img_slot->data[1]=0x0x704fe008
[01-01 12:53:23][pid:0][OTHER][ERROR]del_gateway ioctl error and errno=3
[01-01 12:53:23][pid:0][MOBILE][ERROR]comm_param is null.
Jan 1 12:53:23 bsp.err kernel: [ 78.126377] nvt_i2c f03a0000.i2c3: i2c_nvtim_xfer_msg(675) NACK!
Jan 1 12:53:23 bsp.warn kernel: [ 78.126397] [LOCALVIDEO][tp2803fc_check_exist]:i2c_reg_read_byte TP2803_REG_ID_H(0xFE) error!
Jan 1 12:53:23 bsp.warn kernel: [ 78.126411] [LOCALVIDEO][cvbs_chip_check]:cvbs chip TP2803_FC is not exist!
Jan 1 12:53:23 bsp.warn kernel: [ 78.126416] [LOCALVIDEO][cvbs_chip_match_for_i2c]:cvbs_chip_check failed! ret = -1
Jan 1 12:53:23 bsp.err hal_bsp[916]: [HAL_BSP][916][localvideo_hwinfo_init]:localvideo init failure, ret = -1.
Jan 1 12:53:23 bsp.err hal_bsp[916]: [HAL_BSP][916][hal_localvideo_set]:Now not support the HAL_LOCALVIDEO_CMD_GETMODE!.
Jan 1 12:53:23 bsp.err kernel: [ 78.527183] nvt_i2c f03a0000.i2c3: i2c_nvtim_xfer_msg(675) NACK!
Jan 1 12:53:23 bsp.warn kernel: [ 78.527201] [LOCALVIDEO][adv7393_check_exist]:i2c_reg_read_byte ADV7393_REG_ID_1(0x8C) error!
Jan 1 12:53:23 bsp.warn kernel: [ 78.527206] [LOCALVIDEO][cvbs_chip_check]:cvbs chip ADV7393 is not exist!
Jan 1 12:53:23 bsp.warn kernel: [ 78.527210] [LOCALVIDEO][cvbs_chip_match_for_i2c]:cvbs_chip_check failed! ret = -1
Jan 1 12:53:23 bsp.warn kernel: [ 78.527216] [LOCALVIDEO][cvbs_chip_match_for_i2c]:cvbs chip match failed! chan:0 bus:18, addr:42
Jan 1 12:53:23 bsp.warn kernel: [ 78.527220] [LOCALVIDEO][cvbs_chip_match]:cvbs chip match failed!
Jan 1 12:53:23 bsp.warn kernel: [ 78.527224] [LOCALVIDEO][localvideo_cvbs_init]:cvbs_chip_match failed! ret = -1
Jan 1 12:53:23 bsp.warn kernel: [ 78.527228] [LOCALVIDEO][localvideo_chip_init]:localvideo_cvbs_init failed! ret = -1
Jan 1 12:53:23 bsp.warn kernel: [ 78.527232] [LOCALVIDEO][localvideo_ioctl]:HAL_LOCALVIDEO_PARAM_INIT localvideo_chip_init failed!
Jan 1 12:53:23 bsp.info kernel: [ 78.533173] event 4 bind pid 980
Jan 1 12:53:23 bsp.alert kernel: [ 78.534647] -->DWC_ETH_QOS_setsettings
Jan 1 12:53:23 bsp.alert kernel: [ 78.548750] <--DWC_ETH_QOS_setsettings
Jan 1 12:53:23 bsp.warn kernel: [ 78.815524] DWC_ETH_QOS_adjust_link: stop tx/rx^M
Jan 1 12:53:23 bsp.info kernel: [ 78.815539] DWC_ETH_QOS f02b0000.eth eth0: Link is Down
[01-01 12:53:24][pid:0][HW_IF][ERROR]hal_mcu_info_get error ret=-38!!!!
[01-01 12:53:24][pid:0][OTHER][ERROR]systerm error, not find thisfunc uni_get_radar_num
[01-01 12:53:24][pid:904][UNI_IF][INFO]active_interface = eth0
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_auto_dns_enable = TRUE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_davinci_init_finish = TRUE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_pppoe_enable = FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_support_wifi = FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_wifi_cam = FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_overseas_device = TRUE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_support_ddns = TRUE
[01-01 12:53:24][pid:904][UNI_IF][INFO]radar_support_status = 0
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_smartconfig_support= FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]is_PA_support= FALSE
[01-01 12:53:24][pid:904][UNI_IF][INFO]net_boot_debug--79.531:
===Davinci Init Finish...
S: cmd_get_enable_list
[01-01 12:53:25][pid:904][ISP_FRONT][ERROR] db_get_sip_config
[01-01 12:53:25][pid:904][ISP_FRONT][ERROR]param_idx =0
[01-01 12:53:25][pid:904][ISP_FRONT][ERROR]p_sip_para->server_addr =
[01-01 12:53:25][pid:904][ISP_FRONT][ERROR]param_idx =1
[01-01 12:53:25][pid:904][DOME][ERROR]invalid db_decrypt parameter, src len:0
[01-01 12:53:25][pid:904][UNI_IF][ERROR]kill dropbear pid:443 sucess
Jan 1 12:53:24 bsp.err hal_bsp[916]: [HAL_BSP][916][mcu_wait_char]:^M receive time_out^M
Jan 1 12:53:24 bsp.err hal_bsp[916]: [HAL_BSP][916][receive_ack_from_mcu]:receive none from mcu^M .
[01-01 12:53:25][pid:0][ALARM_EXP][INFO]start init eda pubsub
[01-01 12:53:25][pid:0][ALARM_EXP][INFO]start init uv loop filter module
[01-01 12:53:25][pid:0][FACE_SNAP][INFO]event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]lineCross event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]lineCross EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]intrusion event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]intrusion EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]fastMove event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]fastMove EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]loitering event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]loitering EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]objectLeave event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]objectLeave EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]objectRemove event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]objectRemove EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]regionEnter event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]regionEnter EventCapture register ok.
[01-01 12:53:25][pid:0][EDA_EVENTS][INFO]regionExit event register ok.
[01-01 12:53:25][pid:0][EDA_EVENTS][INFO]regionExit EventCapture register ok.
[01-01 12:53:25][pid:0][EDA_EVENTS][INFO]peopleGather event register ok.
[01-01 12:53:25][pid:0][EDA_EVENTS][INFO]peopleGather EventCapture register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]Parking event register ok.
[01-01 12:53:25][pid:0][SMART_EVENT][INFO]Parking EventCapture register ok.
[01-01 12:53:25][pid:0][E^Q[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 0 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 11
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[waterMarkEpt]
[01-01 12:53:38][pid:0][DSP][ERROR]send fail ret= -9
[01-01 12:53:38][pid:0][SYSINIT][ERROR]hwif_water_mark_ctrl failed, chan:1
[01-01 12:53:38][pid:0][DSP][ERROR]1 chan do not support people counting, just return.
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 10 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 12
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[OSDParam]
[01-01 12:53:48][pid:0][DSP][ERROR]send fail ret= -9
[ISP_FRONTC][ispset_param_group_frontc] chan[0], cmd = 34, value = 1
[ISP_FRONTC]get_cur_app_wdr_mode,chan:0, wdr/hlc(0/1):1, wdr_en:0, wdr_level:50
[ISP_FRONTC]viType:56, cap_Mode:54, impl:1.
[ISP_FRONTC]util_trans_sensor_original_size_frontc 0#3840*2160@25fps viStandard = 2
[01-01 12:53:48][pid:0][ISP_FRONT][ERROR]json open failed(No such file or directory): use default params
[ISP_FRONTC]chan[0] dev_type = 0x24043
[ISP_FRONTC]capture_mode_type = 0 crop_x = 0 crop_y = 0 crop_target_w = 0 crop_target_h = 0
[ISP_FRONTC]NORMAL_CAPTURE_MODE
[ISP_FRONTC]match vi (success!!) isp_original_viw = 3840 isp_original_viH = 2160 frame_rate = 6400
[ISP_FRONTC]config_capture_mode_frontc cap dev type = 0x24043
[ISP_FRONTC]config_capture_mode_frontc cap isp_original_viW = 3840 isp_original_viH 2160
[ISP_FRONTC]config_capture_mode_frontc cap image_viW = 3840 image_viH 2160
[ISP_FRONTC]config_capture_mode_frontc cap hdr_mode = 0 frame_rate = 6400 capture_mode_type =0 viStandard = 2
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 20 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 13
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[captureMode]
[01-01 12:53:58][pid:0][DSP][ERROR]send fail ret= -9
[01-01 12:53:58][pid:0][SENSOR][ERROR]cmd [105] fail
[ISP_FRONTC]chan[0] config_capture_mode_frontc ret = -3
[ISP_FRONTC][ispset_param_group_frontc] chan[0], cmd = 34, ret = -3
[01-01 12:53:58][pid:0][SENSOR][ERROR]frontd_lib_param_set err
[01-01 12:53:58][pid:0][DSP][ERROR]config_capture_mode_setting failed
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 30 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 14
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[voStatus]
[01-01 12:54:08][pid:0][DSP][ERROR]send fail ret= -9
[01-01 12:54:08][pid:0][DSP][ERROR]*******chan = 0x1, streamclass = 0x1*******
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->bSmart264 = 0
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->streamType = 0x1001
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->resolution = 0x1040
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->quality = 0x11
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->bpsType = 0
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->bps = 12582912
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->fps = 25
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->IFrameInterval = 50
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.videoType = 2
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.audioType = 0
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.profile = 1
[01-01 12:54:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.b_svc_mode = 0
[01-01 12:54:08][pid:0][CAPA][ERROR]get_current_res_index failed stream_idx = 1, resolution = 251934745.
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 40 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 15
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[audioParam]
[01-01 12:54:18][pid:0][DSP][ERROR]send fail ret= -9
[01-01 12:54:18][pid:0][DSP][ERROR]get AudioParams fail ret= -3
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 1 min and 50 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 16
[01-01 12:54:28][pid:0][DSP][ERROR]send fail ret= -9
[01-01 12:54:28][pid:0][DSP][ERROR]mdk_av_set_audio_enc_type fail ret= -3
[01-01 12:54:28][pid:0][DSP][INFO]HOST_CMD_SET_ENCODER_PARAM streamClass = 1, enc_param.fps=65561, resolution=4160
# [DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 2 min and 0 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 17
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[streamEncodeParam]
[01-01 12:54:38][pid:0][DSP][ERROR]send fail ret= -9
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 2 min and 10 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 18
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[forceIFrame]
[01-01 12:54:48][pid:0][DSP][ERROR]send fail ret= -9
[01-01 12:54:48][pid:0][DSP][ERROR]1 chan do not support people counting, just return.
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 2 min and 21 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 19
[01-01 12:54:58][pid:0][DSP][ERROR]send fail ret= -9
[01-01 12:54:58][pid:0][DSP][ERROR]mask region :[0]
[DSP][LOG] hikdsp still alive [build:Sep 9 2021--15:52:39][boot failed bootInfo = 26]!!!!!!!!! (Has running 2 min and 31 sec )
[PRCS][prcs_com.c: prcs_inner_data_wait:line:663:]timeout errno 110, inner_cmd 20
[PRCS][special/prcs_mdk_com.c:mdk_writev:1329:]mdk_writev err:[-9] type_info:[videoMask]
[01-01 12:55:08][pid:0][DSP][ERROR]send fail ret= -9
[01-01 12:55:08][pid:0][SYSINIT][ERROR]chanIdx:1 stream:1 support
[01-01 12:55:08][pid:0][SYSINIT][ERROR]chanIdx:1 stream:2 support
streamRecord[1]: start...
[01-01 12:55:08][pid:0][SYSINIT][ERROR]chanIdx is 1 stream_max_id is 2
[01-01 12:55:08][pid:0][SYSINIT][ERROR]chanIdx is 1 stream_max_id is 2 cap_value is 16398
[01-01 12:55:08][pid:0][SYSINIT][ERROR]0000000000 chan 1 stream_idx 2 to 0x56.
[01-01 12:55:08][pid:0][DSP][ERROR]*******chan = 0x1, streamclass = 0x2*******
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->bSmart264 = 0
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->streamType = 0x1001
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->resolution = 0x1056
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->quality = 0x11
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->bpsType = 0
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->bps = 1048576
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->fps = 25
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->IFrameInterval = 50
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.videoType = 2
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.audioType = 0
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.profile = 1
[01-01 12:55:08][pid:0][DSP][ERROR]p_enc_param_dsp->encType.b_svc_mode = 0
[01-01 12:55:08][pid:0][CAPA][ERROR]get_current_res_index failed stream_idx = 1, resolution = 251934745.
