Hi all,
I did a search, but can't seem to find a link do download a hikvision firmware v5.2.5_141201.
My issue is I have "four" DS-2CD2132-I 4MM and tried to upgrade all of their firmwares to V5.3.0 build 150513 via my Hikvision NVR and now 2 are good, but 1 doesn't connect and work - 1 still is on the original firmware. I had successfully upgraded two cameras via the NVR (those I bought were supposed to be the same camera, but I believe they are different. The box says DS-2CD2132-I 4MM with V5.2.0_140721).
So the one that isn't working, I tried to downgrade the firmware (tried 5.25, 5.20, 5.14) but with no luck. Now I want to try and get the exact one that the box says it was shipped with. The box has hikvision firmware v5.2.5_141201
Any help or recommendations is greatly appreciated!
Eric
(newbie)
Eric
(newbie)
