- Jul 22, 2015
- 16
- 1
Hello,
I just installed a 2.8mm hikvision 2132 camera above my garage doors. The issue I'm having is the left 1/4 of the image is blurry. If you look at the attached image the grass/mailbox/tree and anything in the street on the left side are much less "focused" than the rest of the image. Is this normal? I have 2 4mm cameras that are fine, along with a varifocal dome..all hikvision. I used a lens cleaning cloth on the camera lens and also cleaned the housing cover...but there was no change. I noticed the foam piece surrounding the lens can be pushed in, but I'm assuming that's just to buffer the lens from the clear dome housing. Anyway, here is a pic.
Thank you.
Thank you.
