Hammerhead786
Pulling my weight
- Apr 23, 2018
- 250
- 165
Will definitely look into a new router (are Asus ones any good?). Also, regarding the steps you gave, how do I find the range that my laptop has/what do you mean by that? (192.168.0.xxx is in the same range as 192.168.0.xxx?) Also, by plug the NVR into the laptop what do you mean? cuz the only connections my laptop has is HDMI and USB...
I use an Asus router with Merlin's firmware loaded on it and I have no complaints. What model laptop do you have? It should have an ethernet port. You would need to manually set an ip address on the laptop that matches the range of the nvr so if your nvr is 192.168.0.22, then the laptop would need to be 192.168.0.x where x is a number between 1 and 254, however, it should not be 22.
