Folks,
I have a DS-KB8112-IM Door intercom that I'm using to stream video near the front door to my NVR. I'd like to integrate this to my SIP server (asterisk) and setup a dial plan so it will call an extension when the button is pressed.
What is weird, is using the iVM-4200 software (Mac OS), I can see under the 'remote configuration' Network->FTP config a SIP server IP address (which is weird anyway of why it would be listed under FTP....) At any rate, there is a field for a SIP server, but there is no other fields for the SIP secret. Under Intercom->Device Type it is set as a 'Door Station'. Not sure if the mode between Door Station and Door Phone changes the configuration menu options or not?
Is there a way to make this work with a SIP server?
Thanks.
-J
Thanks.
-J
