B besharim n3wb Jan 13, 2020 19 2 Port Saint Lucie, FL Mar 8, 2020 #1 I installed 6 new cameras that will not show up on the NVR but is visible in SAPD.
SouthernYankee IPCT Contributor Feb 15, 2018 5,176 5,335 Houston Tx Mar 8, 2020 #2 Provide a network diagram with the IP addresses. Are the cameras plugged into the POE ports on the NVR ? Did you set a static ip Address on the cameras ?
B besharim n3wb Jan 13, 2020 19 2 Port Saint Lucie, FL Mar 8, 2020 #3 I have a static IP set on the camera via SADP. The cameras are plugged directly into the NVR.
SouthernYankee IPCT Contributor Feb 15, 2018 5,176 5,335 Houston Tx Mar 8, 2020 #4 What are the IP address of the cameras? Normally the NVR sets the IP addresses of the cameras for cameras plugged directly into the NVR. What are the TWO IP address on the NVR ? they should be on two completely different subnets. Reactions: alastairstevenson
