- Jun 24, 2015
- 3
- 0
Hello all,
I'm a newbie and I just set-up my first NVR, a Hikvision DS-7716NI-SP/16. It all seems to be working, however, when I login to the NVR via my web browser, go to Playback, and then try to download a video clip, one of two things occurs:
1) If I have my local configuration set to download to the default folder (c:\Users\myname\USSCWeb\RecordFile), the download appears to work, I get the "Downloaded" message, HOWEVER, nothing is actually downloaded into that folder, nor is it downloaded anywhere else on my hard drive. It just doesn't do it!
2) If I have my local configuration set to download to a folder at the root of my C: drive (C:\XYZ), the download does not work and gives an error of "Download Failed".
I'm stumped. Any ideas? I am running firmware V3.1.3 build 141202 on the NVR (this is what came on it). Should I update the firmware?
