U ulissesgrz n3wb Oct 8, 2015 2 0 Jan 11, 2017 #1 hello a im try to enter to menu and no is possible any solution ?
alastairstevenson Staff member Oct 28, 2014 16,239 7,009 Scotland Jan 12, 2017 #2 What do you get if you try the web GUI login?
U ulissesgrz n3wb Oct 8, 2015 2 0 Jan 16, 2017 #3 On try to login show incorrect user and password Have reset password with code but still try to login is the same problem Have try update firmware by tftp and show connection failure and everything is okei
