For your interest: I installed one Seagate Skyhawk 10TB in a Hikvision DS-7616NI-I2 NVR which was running the original firmware (V3.4.2 something I think), it initialized fine. Then I upgraded the firmware to V3.4.90, Build 160926 from here:
http://www.hikvisioneurope.com/portal/index.php?dir=Product Firmware/Back-ends/Recorder/NVR/76 77 96 NI-I/V3.4.90 build160926/&file=NVR_K51_BL_ML_STD_V3.4.90_160926.zip
It has been continuously recording five ds-2cd2345-i cameras for close to a day with no errors so far. I'm using H.265+, variable bit rate highest quality, 10fps, highest resolution.
I just wanted to report that, as I could find nothing to say that the drive would work or not before I tried it.
