Hikvision DS-7608NI-SE2/8P 8 Channel POE Plug N Play Hi Def NVR Recorder
RyanODan
IPCT Vendor
Mar 10, 2014
626
266
Tulsa
[h=1]Hikvision DS-7608NI-SE2/8P 8 Channel POE Plug N Play Hi Def NVR Recorder (Unbranded Version)[/h]
attachment.php
attachment.php
  • Hi Definition NVR Recorder for Hikvision IP Cameras
  • Easy Plug N Play Design: Simply plug the cables in the back and it will send network data and power to the cameras. No seperate camera power supply needed!
  • Built in 8 Port POE switch makes this the easiest IP system you will ever setup. As soon as you plug the cables in the back of the NVR, you will get video feeds up on the monitor, no IP configurations are needed for each IP camera!
  • Records up to 5MP
  • 120 FPS @ 1080p resolution
  • 50 Mbps throughput
  • 3 Year Warranty
  • $299.99
  • Unbranded means there is no Hikvision Logo on the NVR or on the Box. Yes, it does take the exact same US firmware as the branded versions.
Contact me direct to order:
PM / [email protected] / 9185326522
Reactions: Mike
