B boily n3wb Oct 28, 2017 11 2 Jul 29, 2020 #1 Hi guys I am looking at buying the hikvision DS-7608NI-I2/8P nvr I would like to know if this nvr can record 4k@15fps 24/7 on all 8 outputs. thanks
alastairstevenson Staff member Oct 28, 2014 16,408 7,173 Scotland Jul 29, 2020 #2 boily said: I would like to know if this nvr can record 4k@15fps 24/7 on all 8 outputs. Click to expand... It's mostly down to the bitrate that's configured on the cameras. Check out the specifications here : DS-7608NI-I2/8P Hikvision DS-7608NI-I2/8P 8-ch 1U 8 PoE 4K NVR www.hikvision.com In particular this part of the spec : Up to 80 Mbps high incoming bandwidth ensures IP cameras can be connected Click to expand...
B boily n3wb Oct 28, 2017 11 2 Jul 29, 2020 #3 Thanks for the reply it works out to @ 4k to 16mb/s each camera.
