Hi
My Hikvision DS-7608NI-E2 has been working fine for the past 3yrs. I had a gmail account for sending emails of any camera movement. This broke when gmail made their changes at the end of May. Ive since swapped to outlook for email but still having issues and no emails are being sent.
In DDNS section, Im using NO-IP for DDNS Type. However status is "Connect to server failed". I saw a post that said to change TCP/IP DNS server to 8.8.8.8 and 8.8.4.4 but this didnt help.
In the email section, I have it configured as follows:
SMTP Server: smtp-mail.outlook.com
SMTP Port: 587
Enable SSL
Im close to throwing the NVR in the bin and replacing it with a newer model. I also cannot upgrade the firmware as its a hacked version and the manufacturer said it cannot be upgraded. Firmware is V3.4.2 build 160205. Any ideas on how I can fix the email? Happy to change from outlook to another company if that helps..
Thanks
SMTP Port: 587
Enable SSL
Thanks
