Klaus Schmidsrauter n3wb Nov 30, 2017 11 1 Canada Dec 23, 2017 #1 Does anyone know of a way to access the Linux embedded in this NVR? Being able to get to the Linux command line might enable me to check and/or modify the Virtual Host function.
toysareforboys Young grasshopper Dec 16, 2017 45 22 Dec 23, 2017 #2 Be super nice to be able to edit the webpage that shows up when you log into it with Pale Moon too, SO much wasted space on the display everywhere -Jamie M.
alastairstevenson Staff member Oct 28, 2014 16,241 7,009 Scotland Dec 23, 2017 #3 Klaus Schmidsrauter said: Being able to get to the Linux command line might enable me to check and/or modify the Virtual Host function. Click to expand... What do you aim to do?
alastairstevenson Staff member Oct 28, 2014 16,241 7,009 Scotland Dec 23, 2017 #4 I have just seen, and replied, to your other post, with the likely solution to your problem.
Klaus Schmidsrauter n3wb Nov 30, 2017 11 1 Canada Dec 23, 2017 #5 alastairstevenson said: I have just seen, and replied, to your other post, with the likely solution to your problem. Click to expand... thank you
