- Sep 24, 2015
- 25
- 0
Hello,
I have successfully configured like 3 days ago this NVR DS-7608NI-E2-8P/A with a test cam DS-2CD2112-I (waiting for other 4 1080p Exir camera).
But, I have noticed that I have a really curious problem.
The NVR with DHCP enabled doesen't recover automatically from my router (Netgear DGN 2200v3) the DNS Adress, Primary and Secondary.
My router uses the google DNS (8.8.8.8 and 8.8.4.4)...
So to bypass this problem I have to:
1) Disable DHCP (because the DNS space are EMPTY and I can't edit without disabling DHCP)
2) Enter Manually Settings for IP and Gateway and also for the DNS.
3) Enable Again DHCP (because if not enabled the UPNP Service doesen't work)
4) Works fine, because when I enable again the DHCP the DNS bar will be fulled with the Google Dns previously inserted manually.
So you will say that the problem is Fixed... NOT, because every time I need to reboot or shutdown the NVR, the space for DNS will be blank again.(so no connection for DDNS or EZVIZ)
The NVR is like can't take automatically with DHCP the DNS from my router. (other devices in the network have no problem)
Do you have any ideas on how to fix this?
And I have also other questions:
There's any way with IVMS for iOS or other software to shutdown the email notification on motion detection remotely?
And also to shutdown the alarm Output (siren) on PIR detection?
(I know I can do this with DDNS and a PC but it will be really useful to do that with a simple app on smarthphone)
And the NVR can work 24h/7days cantinuosly? Or I have sometimes to shutdown it?
(I have an UPS Interactive Sinewave)
Thanks in advance
NVR Information:
Firm. V3.3.4 Build 150616
Cam Firmware: V5.3.0 Build 150814
European Market Products (not directly from china)
Thanks in advance
NVR Information:
