bengrech n3wb Apr 16, 2018 13 0 Apr 16, 2018 #1 Is it possible to connect more cameras to the Hikvision DS-7604NI-E1/4P if I connect my existing ones to a POE switch, or is this restricted?
fenderman Staff member Mar 9, 2014 36,891 21,408 Apr 16, 2018 #2 bengrech said: Is it possible to connect more cameras to the Hikvision DS-7604NI-E1/4P if I connect my existing ones to a POE switch, or is this restricted? Click to expand... no you cannot
fenderman Staff member Mar 9, 2014 36,891 21,408 Apr 17, 2018 #4 bengrech said: Would the only option be to replace the NVR? Click to expand... yes, or add another... if you really want to step up your experience, consider a software based vms like blue iris or milestone
bengrech n3wb Apr 16, 2018 13 0 Apr 18, 2018 #5 Thanks for the feedback. Will try to look for more info. Can the HIKVISION NVR be flashed with this software?
