Hello,
I've received a ton of info from this forum, thanks for all the help already!
I'm trying to use an Axis M7014 encoder with a Hik DS-7617NI-E2 and having some issues. Has anyone successfully done this?
I'm connecting the encoder to the built-in PoE switch. I'm able to connect the channel 1 but if I attempt to connect to any other channels i get a "Channel No error". I've tried using bot the Axis protocol and Onvif. I can get an image on either for ch1 but unable to access ch2-4 using either.
Anybody know a trick to get this to work?
Thanks
Thanks
