Have a question on configuration of this guy. I am having issues with keeping the nvr on the same subnet as the cameras (is this even possible).
My goal was to keep the cameras on my same internal subnet so I can possibly access them with my vera pro (home automation) hardware at a later time.
I have a fairly simple setup I am running a ZyXEL GS1900-24 switch which is handing out 192.168.1.xxx (from my sophos server - 192.168.1.1).
I have the 7108SN/P configured for 192.168.1.15.
I am using the PoE off of the 7108 to power the cameras. I can plug into the lan ports on the back of the 7108 and gain access to the cameras using SADP and finding them with their 192.168.254.xxx address. I can login to them via the web and force them to use say 192.168.1.16.
I then lose the ability for the NVR to connect to them once I change them to be on the same subnet as the NVR.
So I am assuming that the NVR is running dhcp of its own and I am not able to run both the mgmt side of the NVR and utilize the power over ethernet ports off the back of the nvr to allow my dhcp server to assign address'
I guess what I am getting at is for this to work I assume I will have to purchase a separate poe switch which I will plug the cameras into then back into my ZyXEL switch and ditch using the ports on the nvr itself. Is there any other way around this or am I going about setting this up the wrong way?
In the end I would like the cameras to be accessible to my vera pro so I could possibly tie them into my home automation setup (when I get there)..
Any suggestions are much appreciated!
Neil
Neil
