- Jan 3, 2017
- 23
- 1
Hi, I purchased the above NVR off aliexpress and i'm not too impressed with the motion detection as it seems to trigger all the time without many configuration options.
I would like to use a PC with Blue Iris instead as I've found this to be far superior. Can I use the NVR as a PoE switch only? I've found the hard coded IP's a bit limiting but i read a thread to enable virtual hosts which I'll try.
In addition, I would like to take out the hard disk and attach it to the PC without the awful beeping the unit does without a hard disk.
Does anyone have any tips on how to do this?
Thanks.
Thanks.
