- Jan 22, 2016
- 76
- 19
I've got a Hikvision DS-7108N-SN/P (firmware V3.0.13) NVR and am having trouble figuring out a way to connect to the cameras directly when they are plugged into the NVR's POE ports.
This NVR doesn't appear to have 'Virtual Host' support, and also doesn't have Telnet enabled so I can't enable IP routing like in this thread:
Hikvision POE LAN segment - access to cameras without virtual host or extra wiring.
I've tried using the patch cable from [NVR POE PORT]---->[LAN ROUTER] method which does work... but when I do this the NVR web interface becomes super slow and buggy (often not loading at all). I'm not sure why this is? something to do with increased network traffic? I wish I had just bought an NVR and separate POE switch now.
