- Aug 6, 2014
- 196
- 31
Is there a way to use the presets you set in the Hikvision DS-2DE2A404IW? I set 7 presets that allow me to move the PZT around to different areas, but they don't work in BI 5, or at least I believe they are not working. When I use the web (UI3) interface and pull up the camera so it is the only one. On the left side I see the PRESETS and the oval control that allows you to control it manually, but that isn't working either.
They also don't work in BI-5 Proper.
In BI-5 I set the camera as the Hikvision DS-2DExxxx RTSP and on the PTZ tab I have it enabled and set to Hikvision/Abus.
Posted screenshots of the config. Any help?
