i have a hikvision ds-2cd3345-i camera and if i connect it to the 7204 nvr recorder i cannot get it working
if i connect the camera to a poe switch and i try to find the camera with sapd it wont find it also
the led lights up when i put the lan cable in so i guess the camera should work
please guys need some help here for example is it possible to reset the camera on the hard way with some button inside or remove the battery inside
