HikVision DS-2CD2722FWD-I compatible NVR
johnthirsk
Oct 5, 2018
17
usa
Hello,
I have recently acquired the titled camera and I am struggling to find a compatible NVR.
Preferably under £100 for the NVR as it is only for the one camera, the NVR doesn't need to be the same brand as long as it works!
The cameras uses an ethernet connection
If anyone could link me to anything that would work I would greatly appreciate it
Thank you!
HikVision DS-2CD2722FWD-I is the camera module number
Hello,
Thank you!
if you want to maintain the advanced motion detection options like line crossing you will need a hikvision NVR.
Contact @Jamil JT Wholesaler - Hikvision
