Hello,
I have a Hikvision DS-2CD2532F-IS. It came with firmware 5.2.5, box sticker says 5.3.0, so I decided to try and upgrade from the web interface because I was having a problem formatting the on board SD Card on the camera. That upgrade did not work and I have tried various firmwares with the TFTP tool. The last firmware digicap.dav I uploaded was from this post: http://www.ipcamtalk.com/showthread.php/3408-HIKVISION-mtd-Brick-Recovery-Guide
EDIT: The firmware for my fix is found at this link: http://www.ipcamtalk.com/showthread...are-Downgrader-5-3-0-Chinese-to-5-2-5-English
Here is the Hikvision TFTP log:
There has never been a line that says "System update completed", the TFTP server is alwyas stopped at the last line. (I did the update though a switch, as suggested on the forums)
So, after a power reboot on the camera, the device is listed in SADP but not with IP Address 192.0.0.64. It says 192.168.1.64. I try to access 192.168.1.64 from my web browser and it does not connect. Attached picture of SADP tool.
Thank you for any suggestions!!
Code:
[2015-06-14 13:41:48] TFTP server [192.0.0.128] initialized
[2015-06-14 13:41:53] Device[192.0.0.64]test tftpserver
[2015-06-14 13:42:02] Connect client success [192.0.0.64]Success
[2015-06-14 13:42:02] Start file transmitting[C:\tftpserv\digicap.dav]
[2015-06-14 13:42:22] Completed file[C:\tftpserv\digicap.dav] transmit
