Hi,
i am having problem with the camera for the past couple of months. Some times the problem would appear once in a month, week. Or a dozen times a day. Then the
Nvr ( DS-7608NI-SE/P/8) would go in a abnormal shutdown loop. The problem is that the camera stops to record (its showing the rec icon, but its not working).
I tried to reebot it, restore it, but the problem is keep backing. The only solution that i found is to format hdd (wd purple 3tb). But it takes coming back, after about 500-600gb
of storage is written. Do you have any advice, how to solve this. The camera is bought on aliexpress, firmware 5.20. I have 3 more cameras (one DS-2CD2532F-IS , and two DS-CD2132),
and they are working perfectly.
Thanks
Thanks
