Hello!
I have Blue Iris setup to listen for PIR alerts for a few Hikvision DS-2CD2432F-IW cameras I have. The trigger works like it's supposed to, but I'm having issues getting Blue Iris to record a decent clip: either it'll start later than it should, or it'll cut the recording off even if (I'd think) the alert should still be on due to continued motion.
Does anyone have this working on a decent level? It seems like this is a common setup, so I'm guessing I just need to update some configurations, although I'm not entirely sure as to what that would be. I've attached what my settings currently look like.
Thanks!
Thanks!
