- May 25, 2015
- 5
- 0
I recently bought 5 DS-2CD2432F-IW [TABLE="class: deviceinfotable, width: 690"]
[TR]
[TD="class: rowheader deviceinfotd, bgcolor: #F8F8F8"]Firmware Version[/TD]
[TD="class: deviceinfotd"]V5.2.5 build 141201[/TD]
[/TR]
[TR]
[TD="class: rowheader deviceinfotd, bgcolor: #F8F8F8"]Encoding Version[/TD]
[TD="class: deviceinfotd"]V5.0 build 140714[/TD]
[/TR]
[/TABLE]
I was able to set the IP address, change them to WiFi and get them running, but i find that they randomly seem to lock up and I can not Ping or log into them. I have them going to a Synology Ds214 to store the images. I am only doing Motion detection and not constant recording.
it happens to all the cams randomly. They are throughout a house, Basement, Garage, LivingRoom FamilyRoom, Kitchen. Even the camera close to the WiFi router have this issue. The only way i can fix them is to pollute power. Pulling the power is not ideal since i will be 500miles away and need them to work consistently.
I have them set as i the attachment.
Is there anything i can do to change this behavior?
thanks
John
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
thanks
John
