- Mar 10, 2014
- 717
- 203
I've been asked how to focus the DS-2CD2432F-IW and for those that have re-focused or changed lenses on Hikvision fixed lens cameras, you know it's glued in place, but that never stopped the determined. So I'll give you some pointers.
First, this is the camera with the front dark plate off. I just used a letter opener and popped it off. Start at the top. You will not be able to adjust the lens yet because it's glued in place. Don't lose the parts inside, the PIR dome cover and the clear lens for the lights.
On the back there's a hidden screw under the label. Peel that back and remove this screw to get inside. The back half is held in with simple plastic clips, so just pull the back from the front slowly, one section at a time.
Then there's a bunch of screws. Remove the screws circled in red. Leave the purple alone for now. Caution, under the yellow circle is a circuit board to circuit board connector, so ease it out carefully.
Then the circuit board comes out. You can remove the lens from the sensor by removing the 2 remaining screws circled in purple but don't do it. You can see that there's a blob of glue on the lens where it screws in. Mine is focused as good as I can ever dream off, but if it wasn't the case, this where an Exacto knife may come in handy to remove the glue. To focus, you need to put the screws back that hold the lens in place if you took them out, put the board back together and put all screws back in, and put the back cover on with that one screw. Then plug it in and you can adjust the lens from the front as needed.
I can confirm it's a 4:3 squarish sensor.
That's it. It's not that difficult to do like in the bullet camera that has delicate ribbon connectors, none of that here. I would suggest not removing the lens from the board as I have done as you can accidently touch and contaminate it with your finger oils.
