- Dec 9, 2015
- 14
- 0
What are you using to view the camera?A coworker and I have been trying to view our stream on port 565, but we can't find out what the configurations are. What configurations should we use to RTSP stream our cam? Thanks in advance. View attachment 6864
If you are using the hikvision mobile app, you need to use the media port (default 8000)
What I meant was, browser? android app etc...What do you mean what am I using to view the camera? I'm using a lan to link my computer to my cam with SADP and then using Mozilla FF to view the IP in the URL.
And yes it is on the default port 8000.
what url are you using for vlc?
You should be worried about that, because various methods of accessing the camera require different ports to be open. If your router is a cellular/satellite or wisp service you will not be able to forward ports unless the provider offers a true external ip for you (at a cost)...Not worried about that for now. We've used Chrome, Mozilla, and IE. We just can't get a port open on the HueWei router.
that depends on what you are using to view the cameras remotely? Please state specifically.We have a true external ip. Dont know what settings in that router though.
you should only need to forward the rtsp port...set it back to 554 (for testing)..and forward port 554.Apologies, we are using rtsp player.
