Hi All
Wonder if anyone has seen this and can assist in recovery of my camera. I think in error I have ended up formatting one of the boot partitions trying to reset and boot alternative firmware onto the camera. The camera now u-boots but drops out of the boot sequence and exits at the Protect Shell console. It is unable to find the initrun.sh script and that's why I think it is unable to load the ethernet driver so cannot update via the T-FTP option. Is there anything I can do to get address this?
On boot, I get the following log messages:
Any help will be appreciated.
Code:
NDI>XSRCTETH trim = 00001BF0
dma1 zq_trim[f], ldo_trim[8]
DDR3_2133ver 2.00
ini_ver: 0x60210205
CPU1000 DONE
>dma1 ssc 1
dma ok
2 DR
dma2 zq_trim[f], ldo_trim[a]
dma1 ssc 1
dma2 ok
UNZOK!
Loader Start ...
LD_VER 03.01.07
528_DRAM1_1066_4096Mb_DRAM2_1066_4096Mb 06/18/2021 16:27:02
NAND,BS= 0x00000002
gpio ID2 0x00000000
gpio ID3 0x00000000
SPI NAND MID=000000EF DEV=000000AA
ld.LdCtrl2 0x00000000
LdCtrl2 0x00000000
teeos_addr 0x02000000
uboot_addr 0x0E000000
uboot_size 0x02000000
smp(tee2)
core2_jump_program 0xF07C0500
code2JumpCodelen 0x00000010
core2_entry2_addr 0x01FC0000
core2_entry_checksum 0x0000C40F
core2_entry_program 0xF07C0510
code2EntryCodelen 0x000001BC
0xF07F8000= 0x02000180
core2_reset
2ajcor1awaitump 0x02000180
abceRS2WK2
U-Boot 2019.04-svn1300746 (Jun 18 2021 - 16:27:08 +0800), Build: jenkins-Frontend.BSP.CCI.devCloud-3862
CPU: 999 MHz
DRAM: 256 MiB
l2cache:0
l2cache:1
bootmode = 0 addr=00007e00!
NAND: id = 0xef 0xaa 0x21 0x00
nvt spinand 4-bit mode @ 12000000 Hz
128 MiB
MMC: 0
misc_init_r: boot time: 1351128(us)
misc_init_r: boot time: 1355131(us)
Net: INTER MII
[Uboot] In release mode!
Hit Ctrl+u to stop autoboot: 0
|RCV UDP pack timeout| error: auto upgrade.(error!!)
TFTP server auto connect disabled
Unknown command 'crc' - try 'help'
booting from sys part...
Load kernel to 0xc700000 ...
<sbal_wb_aes_update>...decrypt
<sbal_seboot>body_total_len=7342880
<sbal_seboot>verify success ##successful to load enc_uImage##
gzip_image_size 700b08 image_size e72b3c
nvt_ker_img_ungzip_linux: gz_uncompress linux
nvt_ker_img_ungzip_linux: generating uImage header for linux
CHIP_1.
Succeed!
## Booting kernel from Legacy Image at 0c720000 ...
Image Name:
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 15149884 Bytes = 14.4 MiB
Load Address: 00008000
Entry Point: 00008000
## Flattened Device Tree blob at 0c700000
Booting using the fdt blob at 0xc700000
Loading Kernel Image
Loading Device Tree to 087dd000, end 087fffff ... OK
Starting kernel ...
l2cache:0
Disable MMU
Clear MMU
Uboot L2 cache aux val: 0x72420000
Uboot L2 cache prefetch ctrl val: 0x70000000
Uboot L2 cache ctrl val: 0x00000000
Done
SW2
starting pid 159, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
create static device nodes under /dev dir
>>>run pre_app_hook
done
waiting for /dev/ubi1_0.
waiting for /dev/ubi3_0.
>>>run post_app_hook
Error: not found driver
Run tee-supplicant ...
device open: No such file or directory
Not find initrun.sh!
starting pid 505, tty '': '-/bin/psh'
BusyBox v3.0.0-2726094 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
