Hi,
My email alerts had stopped working, after no luck fixing the issue I decided to upgrade the firmware.
I did an EXPORT CONFIG FILE first when it was on v5.2.0
I then downloaded the v5.3.0 from the Hikvision Europe site, and now I can't login to the camera. 404 language mismatch.
The camera was bought from a genuine seller on aliexpress, seller was cctv camera china, so it came with English settings.
The camera is still recording etc, its just that I can't access it via web.
As I took an export config file backup, what is the best way to get It back working?
