Hello to forum,
I have HIKVISION DS-2CD2141G1-IDW1 IP camera. I want to install it in my home, and can't make it work as it should.
I already have two old low-res IP cameras that work normally, and I bought this because I want camera with higher resolution.
I want this camera:
to record on SD card 24h,
to upload to cloud,
to monitor over the phone on Hikconnect, so far I only managed to work in Hikconnect.
In my home network I have Techicolor modem/router that I got from my ISP (that I cannot replace), these router has very weak Wifi signal , so I attached to it wifi router xiaomi ax3600, and I attached Hikvision camera to xiaomi router. Network is connected to internet and it works OK.
So, problems started from the beginning, because camera was already activated from the factory and I couldn't even log into it. After I reset and set my password I was able to enter in SADP and I enabled DHCP and Hikconnect. But later on, I cannon find camera in SADP anymore.
I installed Hikconnect app on android, I added camera and I can monitor it. But, camera is still connected on LAN cable, even it is WiFi camera, as soon as I disconnect LAN in doesnt work on WiFi and it goes offline in Hikconnect. So, I haven't yet find an option to set it to work via WiFi. I expected it will work as my other two camera work on WiFi out of the box.
I also installed iVMS-4200 3.5.0.7 Client, and it show camera status as online, but when I try to open camera setting it doesn't work, as it shown on screenshot. What can be a problem?
If there is any other detail you need to know about my setup please let me know.
I want this camera:
to upload to cloud,
