I'm just now getting into these and picked up one from Amazon. I thought I would share what I've learned from this particular model since I didn't anything posted about this particular model.
I don't think this is a US retail camera. It came in a brown box with a white label covering the Chinese label on the side. It is loaded with an English UI and has minimal documentation in English.
Default IP was 192.168.1.64. The default username/password was admin/123456789abc.
I noticed some odd things about the NFS/CIFS configuration. I could not format the storage using the root folder of the network share in either CIFS or NFS. It would say completed, but the storage status never updated to normal. I had to create a folder and specify it in the configuration for it to format correctly. It is currently setup to use a 750GB CIFS volume. I've read some had issues with volumes exceeding 250GB, but I didn't have any such issues.
Right now I'm just playing with the camera learning the configuration and behavior. Eventually it will be deployed outside of my personal residence.
