Hi all,
I have recently purchased a DS-2CD2046G2-I with the intention of powering it through POE.
To that end, when it arrived I happily unpacked it and I hooked it up to a TP-LINK POE injector called TL-POE2406. Power all up, and nothing happens. The camera did not appear on the LAN, not at 192.168.1.64 and actually not at all. Not via http(s), not via ping, not via SADC. Link is down, no action whatsoever.
So I used an external power adaptor (12V) and suddenly the cam appeared without issue, was reachable at the usual IP address, and was easy to configure with all possible means.
Is my cam faulty, or are there some rare issues with POE that I should know about? The POE injector is otherwise good, since it powers an external WIFI repeater usually. I was hoping there would be a "POE disable" option in the settings, but there is not, so it should be enabled. I have upgraded firmware to 5.7.1 and it didn't change anything. Otherwise the camera generally works (generally, as it does not display the usual "Playback" header at all between Live View and Configuration... but I will deal with that once the power issue is solved).
Can you think of anything work checking?
Thanks a bunch!
M.
Thanks a bunch!
M.
