I purchased a DS-2CD2042WD-I from NetView and it appears to be an English model camera like they said. (The serial number contains BBWR in it.)
The problem is that I can't use any of the firmware files from Hikvision USA or Europe's site. When I try to upgrade the firmware, I get a message saying "Failed to get the upgrade status". But, I was able to get a 5.4.0.160401 firmware file that worked from NetView directly.
I'm questioning if NetView somehow modified the firmware file to make this work.
Does anyone know what the "Failed to get the upgrade status" message means? Is there a way to tell for sure that my camera is an English model and not a hacked Chinese one?
(On a side note, I'm thinking I'd like to try to downgrade to 5.3 since I'm having connection problems and people here are saying that 5.3 is better. There is a downgrade firmware on this forum, but I'm also not able to get that to work. Before breaking my camera, I'd like to figure out what it really is.)
Thanks!
Thanks!
