Hi I am have a de-2cd2032 cameras and I would like to connect it to my LAN. As I will not be using a Poe switch a power adapter is the only other option. I'm in the UK and I believe I need a 12v adapter, but trying to find the amps it uses it quite difficult. I have looked at the manual online and cannot find anything. For a previous camera ( different make) I used a 12v 2amp and it worked.
which adapter would work in volts and amps?
regards
regards
