R Robetha n3wb Dec 19, 2015 12 0 Dec 24, 2015 #21 you are a genius .... problem solved..all i had to do is switch my apple airport extremes ipv6 from auto to link local only .problem solved ..Thanks for all your help Merry Christmas,,
alastairstevenson Staff member Oct 28, 2014 16,409 7,175 Scotland Dec 24, 2015 #22 Hey, well done for persisting with the problem solving and reaching a fix. Was it this suggestion? Do you have IPv6 enabled on your router? If so, another experiment would be disabling that for a while. Click to expand... We've seen one or 2 posts where IPv6 and Hikvision cameras and Apple are a strange mix. No idea of the underlying cause though.
