Hello, I have a couple of questions / problems with this camera that I'm hoping someone here can help me out with. Sorry about the lengthy post, I'm trying to include all the info that I can into the post.
A couple of years ago I got a Hikvision DS-2CD2032-I camera. I ran a network cable up thru my siding and got a POE injector and got everything set up. I tried the Hikvision software, but ended up using iSpy to have the camera record to my WHS 2011 server and I used the iVMS-4500 app to view the camera on my phone. Every month or so I would delete the recordings from the folder on my server. Everything seemed to work fine, but one month I noticed that there weren't any new recordings on my server. I also wasn't able to use the app to view the camera from my phone.
I went thru a bit of troubleshooting, and am thinking that the issue is related to the DDNS upgrade that required devices to be registered at hik-online.com. I went thru the steps on the site, but haven't been able to register the camera. Below are some screen shots of the pages / errors that I'm receiving. Hopefully someone can give me some direction / assistance.
These are the pages that come up when I go to "www.hik-online.com/dar124".
Then when I go to the new "www.hik-connect.com" site and log in to try to add my camera with it's serial number I get the error that the device is offline.
The camera still lights up red at night, so I know it's getting power. I did borrow a new POE injector from work and I get the same results. I'm trying to avoid removing the camera from the house, as it was kinda tricky to get everything wired up behind the siding. I would also be ok w/ doing some sort of "reset" on the camera and starting the config from fresh from the beginning (if that's possible??)
I was also told to update the camera's firmware. Its currently on v5.2.0 build 140721 and I know there is a v5.4.0 build 160530 out there. But I'm not sure how to update the firmware if I cant access the camera via the web browser??
Thanks in advance for any assistance w/ this.
