where can we get this firmware?
by looking into it deeper, for the frame rate, it looks like latest fiormwares locked it at 12...
A poste confirmed older firmwares didn't have that lock (22fps, not 30 but still better)
Sweet! LTS is releasing an ONVIF compatible doorbell with SD card slot and 940nm IR
Any idea why Hikvision did that? Don't get it...
I downgrade to V1.4.62 build 171201 and was able to set "full rate" or 22fps...
no idea about the rest of my issue...
Is that what's referenced in the link in the post 2 above?Where can I find this magic V1.4.62 build 171201 firmware with the possibility to set 22 fps?
Hi, I disconnected JP14 and JP15 yesterday, and while night vision is now greatly improved, it appears that motion detection recording in night view no longer works. I continuously record via NAS (because alarm recordings aren't supported in Surveillance Station) and was able to confirm there was an event at 4:55am in front of my door (happens around the same time every morning, because it is a paper delivery) but it was not detected or recorded via the app and onboard storage card. Events that took place when night vision switched to daytime, do detect motion detection events.
did you try it?@asustitan Found this same file on another website, but there is a note that this firmware is only for KB6403. Does this mean that the 180809 version might not compatible with KB6003?
Took mine apart this weekend, Yep I would think there is room for some near the bottom, Disabled the IR sensors toowonder if there is any room descicant beads?
just to let you know, i just flashed the v1.4,62 build 180809 firmware onto my KB6003 and it works perfectly fine (so far). I am hoping it resolves the intermittent disconnect from hik-connect (which until now has required a reboot vai the ip address config page).No, still on 180726 at the moment.
