hello all ,
I have a Hikvision Dome Camera/eyeball camera which was working fine untill recently.
But the camera is not reponsive anymore. I know the Ip adress. When I directly want to login via my pc with the IP adress , nothing , the webbrowser does nothing.
The Hikvision config tool programm occasionally shows the camera , but not the whole time , maybe 20 seconds or so per 5 minutes.
I have isolated the camera and connected it directly to my PC (connected also with 12 V dc).
I can ping the Ip adress , and get a reply every time.
The Hikvision config tool programm still does the same , it occasionally shows briefly the camera.
When I enter the Ip adress in the webbrowser ...... nothing.
Anything I can still try , or is this camera toast?
Thanks,
Cor
Thanks,
Cor
