- Mar 9, 2014
- 36,891
- 21,409
Many users have taken advantage of the new BI substream option which allows BI to utilize the subtream for decoding, matrix view and now recording continuously until a triggered event, then going to full stream. This saves a ton of cpu. The downside is that in matrix view on a large screen the images can be blurry and that the continuous recording of the 640x480 substream does not produce an acceptable image for some. There is a middle ground.
Newer Dahua cameras by default allow a second substream up to 2mp. The default hik substream is limited to 640x480. Hikvision does allow a 1mp third stream as well however enabling is buried in the menu and requires some feature sacrifice (see image below) though options like the + codec are not compatible with BI anyways. See image below.
The dahua's ability to provide a 1080p second stream vs the 1mp max on the hik and also not having to sacrifice a feature set gives it an edge.
