fenderman
Staff member
- Mar 9, 2014
- 36,891
- 21,409
blue iris works...i have used it with both android and ios apps in the past..i havent tested ios with BI4...I just tested with iVMS-4500 mobile app and works as expected. I do not own any android device.
Since iVMS works then settings in the camera are ok. What can I set in BlueIris for this to work?
Android works as expected...with g711ulaw....you must have something set incorrectly..dont know what it is though...
Ivms always worked a bit better though...
