I bought some new Hikvision 4MP cameras (DS-2CD2042WD-I) with firmware v5.3.3 on them, so I tried to use them with the Hikvision 7104NI-SL/W but they don't show any video. The main screen shows no video on it, even though it's added to the NVR.
I activated the cameras using SADP v2.2.3.6 and changed the default password to Password1, set a static IP on the camera, and try to add it using the static ip I assigned, management port of 8000, username admin and password Password1. When I hit add, the NVR tries to connect to it but after 1 minute, it says disconnected but the NVR can read the camera model # and firmware number. The strange thing is when I use the search button to find cameras with the NVR, it says 0 channels are available.
I can connect to the camera directly via Internet Explorer and I can see the streaming video with the correct credentials.
I have another machine from Hikvision (7608NI-E2/8P), and it works fine with the camera, so I know the camera works but it just won't work with the 7104NI-SL/W. Does anyone have any experience with this? I'm out of ideas and I'm afraid that this particular NVR doesn't work with it and I need to get another model. I'm looking to use the cameras to just stream without any recording, so I'm looking for the cheapest NVR that will allow me to stream to a TV/monitor.
