It's got nothing to do with quality this is simply a case of updating a China region camera with Western firmware.Never fixed mine, spent hours on it, went out and bought a better quality camera. The hikvision is now a door stop to my study.
...well that's another argument, eh?
Which means it's simply a case of @pr1970 making a newbistic mistake. Camera quality has nothing to do with it.
Alternatively, if you want to argue that the firmware update routine should check to ascertain that the firmware being applied is the correct firmware for the camera and -- as a result -- the quality of the firmware update routine is severely lacking...well that's another argument, eh?
Yes stupid me for following the manufacturers instructions to update its firmware going by what the label on the camera said to fix a problem of not working with ftp domain names...
I did not say you were stupid pr1970, nor do I believe that you are stupid. What I did imply is that if you were more experienced -- and had researched upgrading the firmware on this camera -- you most likely would have uncovered the fact that the camera was a "Chinese Region" unit and that a firmware upgrade was a ticket to brick it.
...But in this case I think unless the seller indicated customers shouldn't upgrade at point of purchase then I wouldn't expect camera owners to know. Even if OP had read firmware update notes and glanced at Hikvision's websites etc it wouldn't be obvious. Sure coming on this forum and reading a bit would ring alarm bells for someone thinking of upgrading, but most people are understandably only going to do that when a problem occurs.
The firmware flash routine is PROFOUNDLY DEFICIENT in that the camera flash routine fails to check that the firmware being flashed is appropriate for the camera; the result is that the consumer destroys the camera by flashing inappropriate firmware.
You didn't buy a local produced camera unless you live in China or Korea...if it took you a few hours to setup a hikvision camera then you simply don't know what you are doing... This is why manufacturers don't like selling to and supporting end users...Yes stupid me for following the manufacturers instructions to update its firmware going by what the label on the camera said to fix a problem of not working with ftp domain names.
I bought a local produced camera for £60 more, the quality is better and it comes with a great ios app and worked out of the box, and i`ve updated the firmware remotely without a hitch. I had it setup and running in 15minutes of taking it out of the box. The hikvision I spent a few hours initially and then a further 6+ hours trying to fix issues with it. Utter cheap junk as far as i`m concerned.
The issue is though the firmware upgrade routine is good and does check to make sure appropriate for the camera. But because the firmware is modified so the camera thinks it's English/World region, things go awry and the routine then thinks the firmware is appropriate so the safety check falls down a bit...
So why isn't the flash routine checking the camera's serial number to determine is the firmware is correct? This seems like a very easy issue to fix by the developer.
I guess because the way it's coded would mean if they took CH in the serial into account, the camera would identify itself as Chinese. Then the hackers would be forced patch the serial so it would be read WR - that would lead to even more confusion for people trying to identify the firmware to use for their camera.
When will the madness end?
