S snice n3wb Aug 28, 2014 15 1 Jan 27, 2015 #1 Hi, Did anyone managed to use no-ip services from Hikvision cams? Here is my actual config: But no update is done on no-ip server. Thanks for your help Attachments noip.png 14.5 KB · Views: 81
fenderman Staff member Mar 9, 2014 36,891 21,408 Jan 27, 2015 #2 Are you getting email alerts? In you tcp/ip tab..make sure your DNS is set to google 8.8.8.8
Mike Staff member Mar 9, 2014 3,001 2,844 New York Jan 27, 2015 #3 You have to input your no-ip.com username too. Don't use your full e-mail address, it won't work like that. Use just the username.
S snice n3wb Aug 28, 2014 15 1 Jan 27, 2015 #4 fenderman said: Are you getting email alerts? In you tcp/ip tab..make sure your DNS is set to google 8.8.8.8 Click to expand... Didn't try email alert. The DNS was my router's address: 192.168.1.1. Changed it back to 8.8.8.8 Before changing it back to 8.8.8.8, here is a ping from the camera using ssh: and here with 8.8.8.8 as DNS server: Attachments ping1.png 43.1 KB · Views: 63 ping2.png 27 KB · Views: 62
S snice n3wb Aug 28, 2014 15 1 Jan 27, 2015 #5 my no-ip username is there, you don't see it because I hide it for the screenshot and it's not the email address.
fenderman Staff member Mar 9, 2014 36,891 21,408 Jan 27, 2015 #6 Did it work after you changed the dns to google?
