- Sep 4, 2016
- 30
- 2
Anyone have any experience with the Hikvision AcuSense PCI-B18Z2S camera?
I gather it has a motorized lens, but it doesn't say so in the description, like it does for the non-IDS version.
I know it's POE, but I don't see any pictures showing the actual connection. I saw a video of the non-IDS version and the POE connection seemed to be screw connections. It was not conclusive from the video.
It says the audio In/Out are 3.5 mm, but there are no pictures of these connections, and I don't see an accessory for these connections.
It says the minimum illumination for color is 0.003 lux. I gather this is with the white lights turned on because the Non-IDS camera has the same IR array, but the minimum illumination for color is .01 lux. I assume these lights are like the lights on the ColorVu camers; i.e. likely to annoy the neighbors?
